Information screen warning clearance
KARLEWP1
Postby KARLEWP1 » Mon Sep 14, 2020 3:38 pm
Good afternoon.
My 2008 XKR inadvertently had the inclination/tilt sensor activated. I have cancelled the alarm but the centre console information screen shows the message : Alarm triggered by Inclination sensor. No warning triangle is illuminated. Is there a way of clearing this message without a visit to the local dealership?
Thanks and regards Wayne.
JimMann
Re: Information screen warning clearance
Postby JimMann » Mon Sep 14, 2020 5:26 pm
Hi Wayne,
If you take the car for a drive of around 10 miles, the reset should happen by itself.
Jim
Jim Mann
Banchory
KARLEWP1
Postby KARLEWP1 » Tue Sep 15, 2020 10:31 am
Good morning Jim.
Thanks for the advice. I will give it a run as you suggest.
Regards Wayne.
KARLEWP1
Postby KARLEWP1 » Tue Sep 15, 2020 8:27 pm
Good evening Jim.
Tried the ten mile plus run and, sadly, no joy with clearing the message. Looks like a dealership visit when next the car requires a service.....June next year!
Thanks anyway.
JimMann
Postby JimMann » Wed Sep 16, 2020 9:26 am
Hi again Wayne, that's strange as that trick usually works. The alternate solution, if you have either breakdown cover or a local friendly independent garage, both will happily plug in a reader and clear the codes. I realise you are not supposed to call the breakdown service on a spurious call-out, but if they have to be attending because you are concerned about a fault warning, then they will plug in the code reader as a first step.
Jim
Jim Mann
Banchory
KARLEWP1
Postby KARLEWP1 » Thu Sep 17, 2020 8:42 am
Thanks Jim. The AA it is then!
