Rear speakers 1998 Xkr converntible
johnhughes170663820
Postby johnhughes170663820 » Fri Jun 14, 2019 3:22 pm
Can anyone help i have stripped down my rear qtr and removed speaker which is shot the speaker was hard wired even though it had a plug. I took it to a shop and they told me its a sub not conventional speaker?? Can anyone advise a suitable option for replacement and do you know if its a sub or speaker there is no part number on speaker not sure its a genuine speaker fitted my system is Harman Karden system
Astromorg
Re: Rear speakers 1998 Xkr converntible
Postby Astromorg » Fri Jun 14, 2019 7:17 pm
IIRC, the speakers are not of a 'standard' size, so if it were mine I'd be phoning (not emailing!) Eurojags on 01325 722777 and getting an immediate response about availability and price of a good, used one.
Website at www.eurojag.com is a guide but doesn't cover their full, up-to-date stock, hence the phone call.
2005 XK8 4.2-S Coupe
2024 XE 300 Sport
johnhughes170663820
Postby johnhughes170663820 » Fri Jun 14, 2019 10:23 pm
Hi thanks for the help my concern is fitting second hand parts like speakers i may be replacing item with something of poor standard after all they are 21 years old and speaker material does degrade. I was hoping someone may have made a change to something more modern and if so what did they use as i have mixed info if this is a sub or speaker and need to understand this before i replace I have hunted for new bit failed to date and judging by the costs i am seeing they would be extremely expensive if i found one. But thanks again for your feedback. If anyone has changed there’s out please get in touch i would appreciate your input
johnhughes170663820
Postby johnhughes170663820 » Sat Jun 22, 2019 8:10 am
Hi just to let everyone know i purchased a pair of £50 mid range speakers and fitted these even though they were subs originally they work perfectly well just in case anyone else has same worries or concerns
