Page 1 of 2
Back Boxes
Posted: Sat May 18, 2013 1:08 pm
by para
Hi guys
Just changed the two back silencer boxes on my xkr for a straight through system. Lovely burble on tickover, great sound, not intrusive. If anyone is thinking about changing the back boxes i can recommend this system
Regards Para
Re: Back Boxes
Posted: Sun May 19, 2013 10:17 am
by mike020150
Fortunately, Jaguar has at last (2006 onwards) realised that a V8 makes an evocative sound which should be released to be enjoyed and not entirely throttled. :D Mike.
Re: Back Boxes
Posted: Sun Aug 18, 2013 10:59 pm
by davidt34
Hi guys
My 1997 xk8 has some Rezistanz end cans fitted which sound great. Not sure where the previous owner got them from but I love the sound!
Dave
Re: Back Boxes
Posted: Mon Aug 19, 2013 8:15 am
by ihouston
I have just removed my back boxes and agree sounds like a V8 now and just about right on the noise level
Re: Back Boxes
Posted: Sun Dec 28, 2014 6:20 pm
by PTR200Jag
Sorry to resurrect this thread but didn't want to open a new one for existing info.
Just wondered how the straight through pipe replacements are going, do they drone at all at certain revs?
or is there some sort of silencer modification that can be done to help liberate the V8 sound :lol:
Re: Back Boxes
Posted: Sun Dec 28, 2014 8:20 pm
by mike020150
The trouble with releasing the V8 burble is that one man's burble is another man's racket! The easiest/cheapest mod is replacement of the back boxes by straight through pipes. Many have done it. Indeed, the JEC used to sell the pipes to do it. The result is quite pleasing to most of us. However, it does introduce a resonance at just under 2000 revs which may make legal motorway cruising slightly less pleasant. When my car was equipped this way, I as happy to live with it by cruising just a little quicker to avoid the resonance. Nevertheless, it doesn't suit everyone. Perhaps someone at your local meeting with a car modified this way would be prepared to demonstrate it to you? If so, you could make up your own mind whether it would be OK for you. Alternatively, there are many thunderous exhaust systems available from nearly sensible to downright expensive! Mike.
Re: Back Boxes
Posted: Mon Dec 29, 2014 9:59 am
by daveji
I agree with Mike on this.......its all in the ear of the listener !
I use my convertible to enjoy driving "top down" in the fine weather.
For me...... there is nothing like ambling (briskly)around the local byways in the sunshine with the stereo playing my favourite bits of Classical
The exhaust note for me is just right.....and it turns into a more purposeful growl when the
right foot goes down !
I reckon Jaguar have got it just right......nicely refined !
Re: Back Boxes
Posted: Mon Dec 29, 2014 10:21 am
by PTR200Jag
Thanks for the info, just wanted a little more, as you say "burble" not intrusive and no resonance to speak of, I can live with it around 2000 rpm as I tend to run around 23-2500 on the motorway on which I travel rarely, when I come to think about it.
If I need a ludicrous V8 burble I just need to get in my Triumph TR :shock:
Re: Back Boxes
Posted: Mon Dec 29, 2014 10:23 am
by PTR200Jag
Is your car a late version then, with jaguars "modified" sound ! ?? or do you mean you have the straight through pipes replacing the rear boxes?
Re: Back Boxes
Posted: Mon Apr 06, 2015 12:31 pm
by PTR200Jag
Hi guys
Dave
Just changed my pipes for the straight through version, including the Rezistanz end trims. Sounds much better, slight "drone" between 1800 and 1900 revs but I can live with that, 2100 is seventy ish and its gone by then.
Definitely a nicer tone and still very quiet at low revs, including tickover, doesn't sound like popping in a metal tube either. :lol: not raucous or intrusive at all.
Tootling around town and the country lanes produces a nice subtle sound and putting the foot down, well, that's something else!! :twisted:
I have kept the original silencers, which are in very good condition, cleaned and sprayed up with maintenance fluid they will be stored away....just in case I need to revert back to standard.
Re: Back Boxes
Posted: Mon Apr 06, 2015 2:44 pm
by mike020150
With such wonderful Easter weather, what could be better than listening, top down, to a burbling Jaguar V8? :D Mike.
Re: Back Boxes
Posted: Mon Apr 06, 2015 8:56 pm
by raysearles
Listening to a burbling V12 E Type of course Mike
Re: Back Boxes
Posted: Tue Apr 07, 2015 10:22 am
by mike020150
Ah but the joyous noise of a V12 is under power with a few revs on the clock. The V8 excels at waffling. Each has its place, don't you agree? Mike.
Re: Back Boxes
Posted: Sat Nov 28, 2015 4:20 pm
by gsxr1000
After reading these reports online with interest and also in the various Jaguar magazines I decided to replace the rear sections on my 2001 XKR to release the burble a bit. I didn't want any intrusive noise especially when cruising so anything more than the rear sections would probably be too much. I saw an ad for Double S exhausts in Jaguar World and they seemed well priced and well made so I placed my order. They do without the last two silencers fitted as standard as you might expect. Now they are fitted they have proved to be everything I wanted. The noise at idle isn't too 'look at me' but it does give off a suitably meatier tone than the originals and accelerating either from a standstill or at pace certainly sounds a lot better to my ears. The welcome surprise is that whenever you are off the throttle, such as at a steady speed on a motorway, there is no resonance or droning at all. They actually sound like the standard pipes. But when you want to pass someone the glorious sound returns to put a smile on your face. £200 (plus fitting) well spent I reckon. The only minor observation I have is that the chromed finishers look as if they are on the wrong way round as the side to side curvature is the opposite to the form of the bumper ie they stick out further at the outer edges. The tops are fine, sticking out slightly further than the lower edge. I need to look at a few other XK8/Rs to see if this is normal (or can anyone here advise?). If anyone is thinking of swapping theirs I would recommend these with no hesitation. Shame that the weather at time of writing is too rotten to get the car out to experience it a bit more but the anticipation is building nicely...
Re: Back Boxes
Posted: Sat Nov 28, 2015 4:27 pm
by mike020150
You'll have to bring your car along to a forum meeting next year to let everyone hear and enjoy the end result. Listening is always better than talking about exhaust noise. Mike. :)
