I have a 2003 XK8 and was wondering if someone could tell me when Jaguar started fitting the redesigned/uprated water pump as standard.
It appears from the parts list that the part number remained the same through to 2005.
Doug
Water Pump
Hi Doug
The original (& 1st attempt to get it right) is a single casting with 5 bolts fixing to the engine.
The latest pump is a 2 part casting with extra bolts to hold the 2 parts together.
As far as I'm aware no 4.0 engine had the latest pump fitted in the factory but all 4.2 engines did.
New pumps from Jaguar are about £60.00 (including latest gasket)
Allan
Allan
