Hi All,
I'm having problems and need help to source the described parts.
This short metal pipe NCA3148AA connects to the side of the XK8 4L (1997MY) engine block, positioned just above & behind the starter motor and takes coolant water to the throttle body water jacket.
The metal pipe is secured to the engine block by a 'Banjo Screw Fitting' NCA4623AA & two copper washers AJ*11945.
My pipe has corroded and is dripping coolant water onto the starter motor & steering rack.
Jaguar have the parts listed as diss-continued and so I need to try to source some good/used parts to exchange out mine.
My car is with Clive @ Nene Jag Specialist garage currently and he's also trying to source the pipe & banjo nut.
I'd appreciate any leads or suggestions of where I may purchase the parts from.
Thanks in advance for any replies.
Gary.
Steel water pipe leaking from Banjo fitting
Re: Steel water pipe leaking from Banjo fitting
These guys may be able to help, worth making contact at least.
https://handler.lv/en/Product/JAGUAR/NCA3148AA
2012 XKR, Black pack, Aero pack, Speed pack
Past:-87'XJS 3.6L, 93'XJ40 3.2L gold, 95'XJ6 4.0L sport, 00'XJ8 3.2L sport, 2005 XK8 4.2L, 2009 X150 5L Portfolio coupe, in that order and enjoyed all of 'em.
