Hi, I have a 1996 XK8 coupe, all works well, however even on a long trip, on switching off the engine the cooling fans only remain on for approx 30sec - is this normal? I would expect them to carry on cooling for at least 5mins....
Would appreciate if anyone advise if this is normal or where the sensor is located and how to test?
Many thanks
John
Cooling fans not on after engine switched off
Re: Cooling fans not on after engine switched off
It's some years since I ran an X100 but I don't recollect in typical use that the fans ran for long periods after switching the engine off so I would say what you describe sounds normal. Mike.
+1. I'm not really aware of my fans ever running on, even after fast runs in the hottest weather.
You can monitor the actual coolant temperature using a scanner such as Torque on your mobile phone to see what the temperature is just before you shut down, but of course to check the temp after shutting down means at least turning the ignition back on that might set one or both fans off anyway!
Bearing in mind that these cars were designed to be able to operate in hotter climates than the UK, there's probably a reasonable amount of spare cooling capacity if the system has been properly maintained
2005 XK8 4.2-S Coupe
2024 XE 300 Sport
2024 XE 300 Sport
Thank you for the reassurance.
John
John
John
John
