Have any home mechanics replaced the upper rear wishbones on a x150 2006 Cab?
Posted: Sat Apr 19, 2025 11:03 am
Have any home mechanics replaced their upper rear wishbones on a x150 NA 2006 Cab?
I am about to attempt this.
Not that the workshop manual suggests it, but after thinking it through I'm leaning towards removing the rear shock absorbers, as access to the rear nut and bolt on the upper wishbones is very restricted. I shall also be replacing the lower rear wishbones at the same time. My feeling is remove the lower wishbones first (supporting the drive shafts) further aiding access and leverage on the rear nut and bolt on the upper wishbones.
I would be very grateful if anyone has any experience of this task and can offer any tips.
I shall be removing the rear brake calipers prior to starting the task as they are going to be replaced.
Many thanks in advance.
KR Mike
KR Mike
