Cats Suspension
DougX
Cats Suspension
Postby DougX » Fri Apr 14, 2023 3:14 pm
Can anyone tell me what the Jaguar Part Numbers are for a 2004/5 front and rear suspension dampers. Mine has the CATS system.
Lucky
Re: Cats Suspension
Postby Lucky » Sat Apr 15, 2023 8:25 am
Have you looked at the Jaguar Classic parts website?
https://parts.jaguarlandroverclassic.co ... xk8-parts/
2001 XK8 4.0 Coupe in Quartz
DougX
Re: Cats Suspension
Postby DougX » Sat Apr 15, 2023 8:34 am
Yes, but I am not sure whether adaptive control damping is the CATS system. Do you know?
Lucky
Re: Cats Suspension
Postby Lucky » Sat Apr 15, 2023 8:44 am
Have you tried ringing the parts department of your local Jaguar dealer? They will search by VIN number. Some are reluctant to give out part numbers so you don't just go and buy the stuff elsewhere, but to be honest I would buy it from them anyway. Tell them you are a JEC member and you might wangle a 10% discount.
Re: Cats Suspension
Postby mike020150 » Sun Apr 16, 2023 10:26 am
CATS is simply the marketing term for adaptive dampers. To replace your units, like for like, you will need to supply your VIN because there are different versions. If you send me the VIN via a pm, I could attempt to reduce the number of likely options. Mike.
DougX
Re: Cats Suspension
Postby DougX » Sun Apr 16, 2023 1:48 pm
Hi Mike, I have sent you my VIN number by PM. I have had a look at some of the suppliers of adaptive dampers and there seems to be another requirement. They have indicated that the adaptive dampers are suitable only to models with 'R Performance options'. I have no idea if this relates to my car, except mine came out of the factory with Brembo brakes and 20" wheels.
Re: Cats Suspension
Postby mike020150 » Sun Apr 16, 2023 5:30 pm
Pm sent with car spec and part numbers. Mike.
DougX
Re: Cats Suspension
Postby DougX » Sun Apr 16, 2023 6:12 pm
Thanks again for the details and part numbers needed for my car. I just wonder how long the dampers are expected to last. The front’s have been on the car since manufacture and the rears were put on 10 years ago, having just covered 39k miles. The car has now done 75k. Any ideas?
Re: Cats Suspension
Postby mike020150 » Mon Apr 17, 2023 9:27 am
Dampers are rather like brake linings in that their lives can be very variable but they are definitely 'consumables'. These days, with the state of our roads, they have a hard life. 60k/70k miles is not at all unreasonable. However, lack of use can also play a part. Lack of use can promote corrosion on the moving surfaces, which in turn, can damage the oil seals and causes fluid leaks. Mike.
DougX
Re: Cats Suspension
Postby DougX » Mon Apr 17, 2023 9:44 am
Thanks Mike. The car is going into a franchised Jaguar dealer for service and mot (which I always get them to service and repair it) next month. I will ask them to check the suspension while there.
leelane588
Re: Cats Suspension
Postby leelane588 » Thu Jun 22, 2023 7:28 pm
Hi all,
Silly question I suppose but how can I tell if my Jaguar XK150 2007 has cats suspension please?
DougX
Re: Cats Suspension
Postby DougX » Thu Jun 22, 2023 8:09 pm
All X150 XKs have a double wishbone with coilover spring, anti-roll bar and damper set-up at the front and rear. Jaguar offered its (CATS) Computer Active Technology Suspension as an option when the XK was first launched but soon made it standard across the board. To check if an XK has this suspension, look for a wire coming out of the suspension tops under the bonnet.
leelane588
Re: Cats Suspension
Postby leelane588 » Wed Jul 05, 2023 7:13 pm
Thank you for the help - really appriciate it
