Hello All
I'm trying to locate Rear Coil Springs for Convertible XKR 2002 is this the correct part Ref/No; ?
Kit Road Spr Rear JLM20589 (Adaptive Damping) VIN: SAJAC42N12PA30375
Any assistance would be V helpful
Best
Clive
XKR 2002 Rear Coil Spring is this Correct
Re: XKR 2002 Rear Coil Spring is this Correct
Well, I can't say for sure exactly what fits your requirement, but Berkshire Jag Components offer this with the part number you give
https://www.berkshirejagcomponents.com/ ... 2x32741483
They specify its for all supercharged models with adaptive damping, but make no mention of coupe v convertible.
SNG Barret list a kit under that number but state its Unavailable. They also list this both up to and from 2002 onwards, specifying supercharged and convertible versions, but nothing about adaptive or not!
https://www.sngbarratt.com/English/#/UK ... 203007693)
but what a price for genuine Jaguar. OEM offer seems better!
Sorry that's all rather mixed messages, but I suggest phone calls to either or both of those providers should clarify exactly what you need. I've found both of them very helpful in this sort of situation
2005 XK8 4.2-S Coupe
2024 XE 300 Sport
2024 XE 300 Sport
The JLM20589 kit is the correct part number for your VIN, assuming it hasn't got the R Performance suspension fitted. Mike.
clivesaunders
Hello Mike & Astromorg
" Thanks " for info I am getting it sorted will be using a supplier of used XK spares; 'Just XK 8 '
Clive'
Clive'
