Rear dampers replacement
Posted: Sun Sep 04, 2016 8:19 am
2001 XKR 81000miles. Severe and varied rattling from somewhere in the rear has developed after a 1400 mile trip in Ireland over some quite rough roads.
I am advised by my local independent specialist that it's probably rear shockers that need replacing but he can't guarantee the noise will disappear!
Q. An estimate of £1300 including Jaguar parts - a fair price? Grange of Swindon wouldn't wouldn't quote without seeing the car for "a health check".
Q. How, apart from the noise, does one tell that the dampers need changing? The ride and handling seems absolutely normal and tyre wear perfect. Could it just be the bottom end bushes, and if so would it be worth just changing them or should I just get on and change the lot?
Q. Is it necessary to change both dampers - it seems impossible to tell which side is making the noise.
Q. The rear dampers were last replaced 15000 miles ago - is this normal wear? They are black and not green fitted by Marshalls of Peterborough - curious why they are a different colour when I presume they are standard Jag fit.
Any thoughts and advice would be much appreciated
Roger G
Roger G
