Hi Have just seen web site for Asda tyres, just put reg in or tyre size and check those available.
Pirelli p zero about £150 each fully fitted.
James.
pirelli tyres
Re: pirelli tyres
Wow!! Need a set for my XKR so will take a look at that!!
Thanks for the tip!
David
Thanks for the tip!
David
Re: pirelli tyres
I checked the Asda site a fortnight ago looking for 20" rubber and received a message saying nothing available or words to that effect so don't get too excited! Mike.
Re: pirelli tyres
A good selection for 19" available and a very helpful price, noise, wet grip, fuel economy and XL (extra load carcass construction) guide on their listings. Makes it easy to compare a varied range of tyres against each other. Price is not the total factor governing tyre performance. The most expensive Michelin Pilot tyre listed is not supplied with XL in its specification.
Prices are in my opinion at typical retail levels. I would certainly be chatting to my excellent independent tame local tyre guy about his best deals on similar products before stumping up several hundred pounds on a new set of boots. I`ve often found he can save me a significant amount of cash when compared to national chains.
Always good to know about what options are available to us.
Re: pirelli tyres
Not a steer to the economy run, but as an alternative I have fitted Dunlop Sportmax RT to my '96 XK8 and the noise difference is remarkable. The performance seems much better than the Pirellis although I don't throw the car into corners. My main concern is wet weather driving and they hold on the wet as they do on dry roads. Much quieter!. They were a bit expensive but well worth the money.
Re: pirelli tyres
Hi, I have just tried to get a replacement rear tyre for my 2005 XK8. The car is fitted with Avon all round. The rears are 285/30/ZR20 99Y's. Can you believe it I have just telephoned Avon and they tell me they don't make them any more!!! They also said they are not making 255/35/R20 97Y's which are fitted to the front, although on surfing the net, I can still see them advertised at certain outlets. My problem now is that I need one Avon tyre and can't get it, which will mean I will have to change both rears. Any suggestions anyone????
- BrizzleJag
Re: pirelli tyres
I'm with Mike in supporting a local independent, by all means price check what's out there. In my experience a good independent is often more knowledgeable and offer better customer service and will do their best to match prices, however even if I have to pay a little more I'd rather have peace of mind that the tyres are fitted correctly and I have the right rubber. My guy is always happy to discuss the merits of one tyre over another which means I'm currently running Bridgestone Potenzas on my XKR. I value their advice and input and have built up a good relationship with them over the years, plus I like to support local business.A good selection for 19" available and a very helpful price, noise, wet grip, fuel economy and XL (extra load carcass construction) guide on their listings. Makes it easy to compare a varied range of tyres against each other. Price is not the total factor governing tyre performance. The most expensive Michelin Pilot tyre listed is not supplied with XL in its specification.
