Replacement Tyres
GEOFFL
Replacement Tyres
Postby GEOFFL » Fri Jan 25, 2013 12:56 pm
Just had my tyres checked over, 2 front 7mm no problem. 2 rear legal but only just. All 4 are different brands so my question is what do existing XKR owners recommend? The car has 20" wheels and does a low mileage (5000 max). I have only had her a month so have had no real opportunity to make any informed decision as to brand. So would be very interested in any recommendations as to what to get - or - what to avoid!!
Many thanks
GeoffL
Happy owner of a 2000 XKR in Phoenix Red with full English Tan leather 63500 miles, Adaptive Cruise, Sat nav, Phone, Cold Climate/Memory Pack, 20" Chrome wheels, Premium Alpine Sound with 6CD changer.
para
Re: Replacement Tyres
Postby para » Fri Jan 25, 2013 4:44 pm
hi geoffl
Its not advisable to mix different brands on these cars but as they are already on you have no choice i suspect you will get differing replys but to answer your question i have dunlop sport maxx j on my 2002 xkr i have had pirelli zeros on other cars i have had but ive found the dunlops superior but thats just my opinion
regards Para
2002 Xkr 4.2 Adriatic blue reg Dez 7571
dhdove
Postby dhdove » Fri Jan 25, 2013 4:53 pm
GeoffL
If you were doing more miles I would say that this is an ideal opportunity to put four new matching tyres on the car. With the rears so low and four different makes currently I think you would see the drive transformed.
However you may think that your low mileage and the expense of four new tyres is not warranted.
It may be worth checking out special offers from fitters, often they have a four for the price of three type offers on.
Do you have a full size spare? Probably not I guess so no way to put one of the fronts on the spare.
I'm sorry I can't advise re brands as I do not own an XK, but I'm sure other members will jump in quickly.
Personally I rate Pirelli and Continental.
On reflection I DO think you should fit four new matching tyres- otherwise when else will you do it?
Best Wishes
TonyS
XJS Bulletin Board Moderator
Postby mike020150 » Fri Jan 25, 2013 4:54 pm
Mixtures of tyres from different manufacturers can produce a car with odd handling characteristics so working towards a matching set could make the car nicer to drive.
If you use the search facility on the bulletin board you will be able to see previous comments about XK8 tyres that you might find useful. Whatever you do, don't be tempted to buy cheap tyres of dubious origin. Jaguar fitted several makes as original equipment, eg Pirelli, Dunlop and Continental and that's a useful guide. Obviously, these manufacturers products will perform as Jaguar intended and each has their supporters amongst the membership. The final decision comes down to personal preference, price and sometimes, availabilty. The new tyre rating label information introduced towards the end of 2012 might prove helpful too. Mike.
oldtimer
Postby oldtimer » Fri Jan 25, 2013 6:59 pm
Just a passing comment,
Would insurers get all "wrinkly lipped" about four odd tyres ?
GEOFFL
Postby GEOFFL » Fri Jan 25, 2013 7:23 pm
Just looked at my winter health check report by my local Ford Dealer (used to have a Ford Fiesta ST and they wrote to me offering a winter health check + top ups for £19.99) Rang to say I didn't have the Ford but was it for any car and was told yes.
So, tyre check - all are 245/35/r20y
Fronts are FALKEN with 7+mm tread.
Rears 1 x VENTUS with 2.7 mm tread
1 x PIRELLI with 2.7 mm tread
So logic and pocket says 2 x Falken required for rears!!
Oh, one bit of good news - the dealer was wrong when they told me the offer applied to any make of car, it was for Ford cars only, so they didn't charge me!!!
GeoffL
Nik
Postby Nik » Fri Jan 25, 2013 8:35 pm
Hi Geoff ,
I've just noticed from your post that your tyres sizes are a bit peculiar :?
You should have if they are BBS
255/35X20" fitted to the front on 9.5" rims
285/30X20" fitted to the rear on 10" rims
I'd also check that the load rating is correct :o
I'm don't know which wheels you have fitted but I note from your signature that have put BBS Chrome ? BBS to my knowledge have never manufactured chrome wheels for X100's ,
can you post a picture of your wheels mate :?:
All the best
Nik
GEOFFL
Postby GEOFFL » Fri Jan 25, 2013 9:46 pm
[img][/img]
Nik - hope this works - no idea if BBS or not, just a guess I think on dealers part. I would love to know what they actually are!!
Geoff
GeoffL
Nik
Postby Nik » Fri Jan 25, 2013 10:13 pm
Hi Geoff,
Not BBS I'm afraid :cry:
I'll do my best to find out for you and report back ,
All the very best
Nik
GEOFFL
Postby GEOFFL » Sat Jan 26, 2013 12:00 am
Cheers Nik, would like to know!! The N/S/F will be coming off shortly as there is a leak on the bead between the rim and the tyre. Kwik fit took a look and said there was signs of corrosion on the wheel and it needs cleaning up and resealing or, better, shot blasting and resealing. The manager knows a local engineering company that can do this. I've also spoken with a specialist engineering company who do motor sport work and does refurbs on split rims. He can't give me an exact price until the wheels off and he can see what's what but says it's usually about 60 quid which sounds reasonable (to me!)
He's based in Wakefield which is only about 5 miles from me.
GeoffL
Postby mike020150 » Sat Jan 26, 2013 11:02 am
Some members have reported the Falkens wear well but are noisy in comparison with the OE suppliers. Another local wheel refurbisher to consider is 'The Wheel Specialist' at Garforth. I can vouch for good service from them plus a discount for mentioning the JEC. Mike.
GEOFFL
Postby GEOFFL » Sat Jan 26, 2013 1:43 pm
Thanks Mike, will give them a ring, they're not too far from me and you can't have too many choices :lol:
GeoffL
GordonJ
Postby GordonJ » Sat Jan 26, 2013 6:43 pm
Hi Mike,
was that a good job as well as a good price, as I would like to get the wheels on my XJ8 done after the winter.
Gordon
XJ6 X350 Sovereign
Previous Jaguars.
XJ8 Sovereign in Seafrost
S Type in Red
Postby mike020150 » Sun Jan 27, 2013 10:25 am
I was very pleased with the service, the price and the outcome, albeit that was 3/4 years ago. I notice from his advertising that the unit is still run by the same man so I'd expect the same results today. It's certainly worth having a chat with him.
When refurbishing wheels, one thing to bear in mind is that Jaguar uses an unusually bright silver paint finish which isn't available everywhere. Powder coating tends to result in a slightly duller finish which isn't a problem if you have all four wheels done at the same time but may be more obvious, and annoying, when only one or two wheels are refurbished and the others are left as supplied by Jaguar. Mike.
GordonJ
Postby GordonJ » Sun Jan 27, 2013 4:02 pm
Thank's for the reply Mike, all these little tips are worth knowing for someone like myself "new to jaguar". It was my intention to have all four done.
Thank you
Gordon
XJ6 X350 Sovereign
Previous Jaguars.
S Type in Red
