Best 18" tyres - in my experience it's Uniroyal Rainspo
MarkyM
Postby MarkyM » Sun Nov 08, 2009 2:09 pm
Bought the car in 2005 with P zero's fitted. Although they had 5mm tread they were quite frankly rubbish and were changed in 2006 to Avon ZZ3's (£520) to get through MOT which were also rubbish after 10k miles. Managed to sell them on Ebay for £200 though :O)
Changed to Goodyear Eagle GS-D3 which were a) very impressive over 23k miles and two x MOT's b) Moderately expensive at £800. Changed due to 2 x similtaneous nails in rear wheels.
Changed to Michellin Pilot Sport 2's which have lasted 2yrs 15k miles but replaced due to poor alignment affecting one of the fronts. Very expensive tyre (circa £1k for all 4 corners although got them on a 4 for 3 offer) and not great wear.
Changed to Uniroyal Rainsport 2 XL which although only having been on the car for 300 or so miles have been through some of the wettest driving I've ever experienced. they are a) Very reasonably priced at circa £500 for all 4 corners inc VAT b) have phenominal grip wet or dry (in fact wet grip is better than dry grip on even the Michellin Pilot Sport 2's) c) Have between 9-10mm of tread from new (most new tyres have 8mm) d) ride is a little noisier (probably due to the blockier tread pattern) but grip and turn-in are amazing.
All tyres fitted have been 245/45/18 front and 255/45/18 rears (I have XKR Double 5 alloys) W rating or greater. The Uniroyal are ZR 103Y XL's.
Uniroyals available via 72hr older from Malvern Tyres.
Mark
PS: I believe that Uniroyal are owned by Michellin
PPS: A well known consumer magazine/website...you know 'which' one :D commented that you could actually buy four RainSport 2's for the price of three of the competitor's tyres while pointing out that the RainSport 2 'has good all-round grip, handles well in wet and dry conditions and resists aquaplaning positively on the straights and in bends.'
Nik
Postby Nik » Sun Nov 08, 2009 5:59 pm
Hi Mark ,
Are they load rated for XK8/Rs :?: , it will tell you on the sidewalls what the rating is ,
Nik
PS I now use Dunlop Sport Maxx , they are brilliant wet or dry :wink:
MarkyM
Postby MarkyM » Mon Nov 09, 2009 8:49 pm
Nik
Thought I said above 103 Y's XL
Sportmaxx are good and rated on tyre review as:
Dry Grip 85%
Wet Grip 78%
Road Feeback 68%
Progressiveness 59%
Wear & Comfort 68%
Buy Again 67%
Whereas Uniroyal Rainsport 2's rated
90% Dry
95% Wet
91% Road Feeback
85% Progressiveness
89% Wear
92% comfort
93% buy again
So on average Sportmaxx scored 70.4 with Rainsport 2's scoring 90.7
So by my reckoning that makes them a better tyre by over 20%?
Mark
Nik
Postby Nik » Mon Nov 09, 2009 11:02 pm
Hi Mark ,
Sorry , didn't read the load rating bit :oops: , if they work out better than the Dunlop's they will be very good indeed :wink:
the Dunlops are streets ahead of the Pirelli's IMHO ,
Nik
MarkyM
Postby MarkyM » Tue Nov 10, 2009 10:29 am
That said tyres are always changing as manufacturers update their compounds.
Take a look at the annual German Tyre Review which puts Pirelli's at the top again!! :shock:
http://www.tyrereviews.co.uk/Article/20 ... e-Test.htm
I notice that Sport Maxx TT's came 3rd but you don't have the TT's do you (I tried to get them but they didn't do in my size)?
My Uniroyal's came in 7th but surprisingly Hankook's came in 4th!!
Amazing stuff and since German conditions/temps are similar to our own they are usually a safe bet (just so long as there haven't been any back-handers!).
M
MarkyM
Postby MarkyM » Fri Nov 13, 2009 8:47 am
Have now done 1000 miles on them and have to say they are excellent to the point of lunacy! :shock: If anyone was driving M25/M4/M5 yesterday they'll know that it was VERY wet.
I have never felt so comfortable with any tyres in such weather conditions ...hence the lunacy comment as you an get complacent like when I coast off the M5 to my junction I normally do so at around 50 so have slowed to 40 by the time I hit the 35 recommendation on the chevrons for the steep curve. At times I've hit the curve at 50-55 on other tyres in the dry and I've felt them start to go :(
Took the curve at 70 last night in the wet and the Uniroyals gripped all the way with not even a sign of twitchiness :?:
Don't get me wrong this is not the way I drive since the car averaged 32mpg according to the tripometre over 320 miles (I think I just don't use m brakes much preferring to anticipate and slow down naturally). Even more amazing when you consider I fill up with LPG at 49ppl :P
I regularly take a braking reaction test (where you shoud find that drivers of automatics always react more quickly since they only have to worry about 2 pedals 8) ) and my average is around 0.4 seconds which puts me in the top 10% of reaction times.
Coupled with the following my cars braking SHOULD be better than most (however what you can NEVER always anticipate is other drivers):
Xenon lights - so you can see better and be seen
EBC dimpled grooved discs - improving braking
Akebono ceramic pads - no dusting/better braking
stainless brake lines - better braking
poly bushes - better feel/ reaction
2005 uprated spings - less flex but better feedback
new front KYB gas adjust and rear bilsteins - consistant ride
nitrogen filled tyres - consistant pressure regardless of environmentals
Tyre pressure monitoring system inc temperature - just to be sure
Oh, Nik what were the load ratings of your Sport Maxx?
Mark
