Brake light switch
Bootneck
Brake light switch
Postby Bootneck » Fri Mar 29, 2024 1:50 pm
My 1997 xk8 4.0 litre comes up with engine failsafe mode. Garage has checked it and advised it’s the brake light switch according to their diagnostic meter. I intend to fit a new one, is there any difference between the switch, my car has cruise control. What part number am I looking for.thanks mike
Astromorg
Re: Brake light switch
Postby Astromorg » Fri Mar 29, 2024 11:33 pm
I've never heard of a brake switch failure causing an engine failsafe situation, just cruise control disabled and maybe traction control in pre DSC models. Any chance of knowing the actual fault code number to see exactly what's going on?
Part number for repro switch at SNG Barrett is LJB6420BB and about £120. Used ones about £50 but not always available. Cheapest and effective economy way is to replace the two micro switches in the assembly. NB the fault is often a dry solder joint on one of the switches and repair is no-cost! I did that 12 years ago and still OK :D
By the way, getting the switch out is quite easy but depending on luck and the physique of the repairer, getting the assembly back can involve removing the driver's seat for access and, literally, the use of fishing lines to get the assembly lined up :(
2005 XK8 4.2-S Coupe
2024 XE 300 Sport
Bootneck
Postby Bootneck » Sat Mar 30, 2024 10:02 am
Thanks, I’ll have to ask the garage next week. I was there when they plugged in the obd2 and it definitely read brake light switch. Thanks for the part number, I thought that was correct but then got twitchy in case there was a non cruise control bit.
Postby ptjs1 » Sat Mar 30, 2024 12:30 pm
Mike,
Before you look at replacing the switch, I'd just check the integrity of the wiring connection on it. It could save you a lot of money!
As regards the part number, just look on the Jaguar Parts website and go through to the Braking System area for your model and you'll find it. See here:
https://parts.jaguarlandroverclassic.co ... xk8-parts/
Bootneck
Postby Bootneck » Sat Mar 30, 2024 6:55 pm
Thanks. I’ll get upside down and check the electrical connection. : 😁
andypryce
Postby andypryce » Sun Mar 31, 2024 5:13 pm
Or, put your phone down there and take a photo, you can then look at it much easier!
XF Sportbrake 2020 / XK8 1998
