In tank fuel pump
Renshaw
In tank fuel pump
Postby Renshaw » Sat Mar 26, 2022 4:54 am
I have a 2006 XK convertible (new shape) and I need to replace the in tank fuel pump my mechanic placed an order with the local Shrewsbury Jaguar dealership and paid for it but they said the item was on back order that was 4 months ago i am still without my car has anybody had the same problem or got any suggestions regards Alan
Lucky
Re: In tank fuel pump
Postby Lucky » Sat Mar 26, 2022 8:36 am
Alan,
Welcome to the forum. You might have more of a response if you post in the XK8 / X150 section of the forum. This section is for comments about the forum itself.
2001 XK8 4.0 Coupe in Quartz
Postby mike020150 » Sat Mar 26, 2022 11:44 am
There are three different fuel pump assemblies listed for the 4.2 litre XK dependent upon VIN number. The oldest version (which could be for your 2006 car) is not listed as being stocked. Without talking directly with Jaguar, there's no way of knowing whether that's a temporary or a permanent situation. Your garage should be following this up for you. If the correct pump is no longer available, I would also suggest asking a local Jaguar specialist if one of the later pumps could be modified to fit without also having to change the fuel tank. Mike.
Renshaw
Postby Renshaw » Sun Mar 27, 2022 1:59 am
Thank you I will talk to my mechanic
andypryce
Postby andypryce » Sun Mar 27, 2022 8:44 am
Also try Eurojag, they may have used one in stock.
XF Sportbrake 2020 / XK8 1998
Renshaw
Postby Renshaw » Mon Mar 28, 2022 4:19 am
Thank you I will call them
