Leaking Fuel Rail Pulse Damper, Fuel Rail: 2003 Jaguar XKR
brm65
Postby brm65 » Fri Sep 17, 2021 9:29 am
Gradual increase of raw fuel smell particularly when cold. I can see a small leak from the fuel rail pulse damper upon start up, which recedes once the car is warmed up. I have read a few old posts on the matter, it seems the damper is available at £120.00, but it necessitates removal of Supercharger and heat exchangers, big job for small part. Anyone had experience of this problem? I would ideally like to just replace the sealing washer(s) but it seems they are unavailable as a separate units. Some have suggested capping off the dampers, there is one on each bank. There is the second-hand option of buying complete fuel rail, but the fuel rail would still have old seals on the dampers.
Secondly, introduction of E10 fuel. I have had to put a few gallons in recently though I don't think it would be that fast acting. The Government website said all Jaguars after 1991 fine to use E10 fuel? Any help, or ideas would be appreciated.
aaj
Re: Leaking Fuel Rail Pulse Damper, Fuel Rail: 2003 Jaguar XKR
Postby aaj » Fri Sep 17, 2021 2:52 pm
Try Richards Bros (01209 212234 - https://www.richardsbros.com/) for seals. A few years ago, I obtained replacement seals for Fuel Injectors on my 2002MY XK8 (they did not do single seals only packs of 10) Much cheaper than a replacement Injector as Jaguar only sold complete Injectors for my MY! Richards Bros were very helpful.
they also service & test Petrol (& Diesel) Fuel Injectors - a good idea to get this done on XK's that are getting on in years.
AllanJ
XK8 Registrar
brm65
Postby brm65 » Mon Sep 20, 2021 2:46 pm
Many thanks for the information. I contacted them today and they were as you say very helpful and they are sending me two seals. I shall have a crack at the job and in the process change the valley hoses which I was planning this winter anyway. I hope after several hours work the new seals hold. I shall report when finished.
