Rear window trim
PTR200Jag
Rear window trim
Postby PTR200Jag » Thu Sep 17, 2015 4:41 pm
Whilst giving the car a good clean down after sorting out underneath the rear arches (dust gets everywhere) I noticed the rear side window trim has lifted up off the window frame / glass.
I pushed it back and it partially clipped in but not properly.
Can someone tell me, perhaps, if it can be pulled off carefully somehow so that I may find out whats gone wrong.
I didn't want to pull on it in case it was fastened someway although I do suspect it is just retained with clips?
If it is clipped do they break on removal?
XK8 MY2002
Re: Rear window trim
Postby mike020150 » Fri Sep 18, 2015 11:11 am
The rear 1/4 window trim 'hoop' is held in position by clips plus a small quantity of sealant at the end beneath the joining piece with the front trim section. The whole thing is removed by peeling back the door seal for better access and then removing the gutter trim before taking off the window trim itself. Mike.
PTR200Jag
Postby PTR200Jag » Fri Sep 18, 2015 3:50 pm
Brilliant, thanks for that, good job I didn't pull it too hard with the sealant holding on to it!
Not sure why the trim is holding off the window at the bottom, but I suspect that one of the clips has let go, broken, rusted, whatever...
Do these trims seal against any water ingress at all?, should there be a bead of sealant along the edge to the window?
XK8 MY2002
Postby mike020150 » Sat Sep 19, 2015 1:49 pm
No, there wasn't any sealant between the trim and the window. the trims are purely cosmetic. Mike.
