Soft Top catching rear seats
Loneranger
Postby Loneranger » Sun Apr 19, 2015 10:33 pm
When lowering the soft top on my 98 XK8 it stops as it is lowering I think that the window in the soft top is just catching the rear seats. Applying a little hand pressure allows it to complete the process. No issues when putting the soft top up.
Has anyone else experienced this? Is there an easy fix?
1998 XK8 Convertible in Sherwood Green Metallic Ivory Leather- Weekend sanity motor 1500 miles pa
2014 Mercedes-Benz C220cdi silver weekday warrior 50k pa
Re: Soft Top catching rear seats
Postby mike020150 » Mon Apr 20, 2015 11:53 am
If the hood mechanism is otherwise operating normally, this problem sounds like an issue with one or more of the hood frame pivots. I suggest that removal of trim/careful peeling back of the headlining to view the pivots will be required to check if a pivot is sticking or excessively worn. Mike.
