Door liner
mick_keates
Door liner
Postby mick_keates » Sun May 03, 2009 2:51 pm
I have a 2003 XKR, the door liner on the driver side has come loose.
How do I remove the liner without messing something up.
Are there hidden fixings to worry about.
BestGear
Postby BestGear » Sun May 03, 2009 10:27 pm
Door liner? do you mean the door card?
If so, the door card is held in pace by plastic pop studs around its perimeter, plus two screws - one behind the door open handle on the inside, and one under the armrest.
You need to remove the window/mirror switch pack, which is held in with one screw too. This is visible when you remove the rubber mat in the door plus the small trim piece between the mat and switches.
The door card simply pops off the door.... working your way around.
Some of the pop studs can break. best repair I have found (tits the pmlastic holder that breaks not the actual pop stud) is to use a holt melt glue gun.
To remove the door card, repair with hot melt gun and replace is around a 40min job total - should not be more, and that time inlcudes time to let the glue go hard.
Hope that helps.
David
