I have a MY 2000 XK8 which is suffering from a water leak on the NS. It's not a lot, but does cause the carpet to get wet. I've replaced both door seals (L & R) and not cured the leak I've priced the body seal which is £195 + VAT! So before I go mad a spend such a lot of money, I wondered if members could assist with the following:
1. Has anyone successfully stopped a leaking door seal by replacing the body seal rubber?
2. If so, is it difficult to fit?
Kind Regards
Tony Nicholls
Leaking door seal rubbers
