XKR - "cruise control not available"
Posted: Mon Mar 16, 2009 6:25 pm
by paulg390
Was driving along in my XKR which I've only had a couple of weeks when I got a warning light on the dashboard saying "cruise control not available".
Did a Google and see that this could be quite serious (financially !) !
Anybody any thoughts or should I go straight back to the garage I bought it from or take it to Jag for some diagnostics ?
Posted: Mon Mar 16, 2009 9:24 pm
by Nik
Hi Paul ,
Whats the year of manufacture and the VIN number of your "R" either the last six digits if it's an earlier car or an A followed by five digits for later examples , I may be able to help :wink: ,
Best Wishes ,
Nik
Posted: Mon Mar 16, 2009 11:38 pm
by paulg390
Hi Nik, its a Sept 2001 R... last 6 are A25507. I've just been out in it and no sign of the warning .. roadlfly posts seem to suggest brake switch maybe the problem ?
Posted: Thu Mar 19, 2009 11:05 pm
by Nik
Hi Paul ,
Yes , the brakelamp switch is a possible cause , your model has TWO microswitches on the same bracket , one for the brake lamps and the other for cancelling the Cruise Control when the brake pedal is depressed , removal of the switch is a doddle , replacing it is a little fiddly and is much easier with two pars of hands :wink: , its bolted through the bulkhead and secured with two 8mm nuts behind the brake servo , I've carried out a quick check for the switch on the Jaguar Electronic Parts Catalogue using your VIN number and it appears that the original part number for the switch was LJB6420BB and has been supercided to LJB6420AB , should cost around £30 + VAT (Your car is a 2002MY)
Hope this is helpful ,
Nik
Posted: Thu Mar 19, 2009 11:08 pm
by paulg390
Cheers Nik - fingers crossed thats the problem... :D
