auto box oil change
Nik
Re: auto box oil change
Postby Nik » Mon Oct 15, 2012 7:39 pm
thanks Doug,
first I have heard of that but worth changing as it seems a likely culprit and much cheaper
than a gearbox. I have a service coming up so will add this on.
As Mike says , get the codes read , ideally when she is in for the service ,
just an observation........... if the gearbox itself is faulty it's unlikely that switching the ignition off and back on will cure a fault on the box , much more likely to be an electrical problem as Doug suggests :wink: and likely to be much cheaper/easier to fix !!
Hope this helps ,
Nik
painter
Postby painter » Thu Oct 18, 2012 2:31 pm
Hi Doug,
do you have a part No. for the 'position feedback switch'? I have been trying to trace this on the ZF box and think it might be the sensor that traces slack between the input and output shafts.
(put simply or in my language). Only two external attachments to the box and it isn't the other one.
doug424
Postby doug424 » Fri Oct 19, 2012 4:47 pm
Hello Painter,
From an invoice from Webbers in Basingstoke, dated 10/6/2005; Switch-Rotary, LJA6201AD was £221.30. Much cheaper fromEurojag.
Doug Barrass,
Ashford,
Kent.
Tommyai
Postby Tommyai » Thu Aug 29, 2013 10:47 am
Hi all, I am going to change the gearbox oil on my 03 XK8 at 65k miles. The specialist has quoted me £27 per litre for the oil and £150 + vat for the replacement filter. I note the previous comments on oil cost ranging from £6 - £13 per litre. ANY pointers here? And should I replace the filter? Total cost for job currently in region of £450. I cannot do this myself as I have no garage or space to do so. And I would like to reduce the cost! Appreciate all/any advice. :)
Postby mike020150 » Thu Aug 29, 2013 11:20 am
Hi Tommyai,
Changing the oil and filter is very sensible. The filter on the 6 speed box is also the sump so it is relatively expensive for a filter but it should be changed. If you can't manage the task yourself (it can be messy/awkward), there are a few ways to try to reduce the cost. The filter and oil costs you have been quoted sound high (main dealer prices) so you could try to source them yourself (from ads in the JEc magazine or elsewhere) and then find a Jaguar or ZF transmission specialist who would be willing to install them. Alternatively, try ringing several Jaguar specialists, some are cheaper than others, particularly if they carry out a lot of transmission oil changes. Mike.
Tommyai
Postby Tommyai » Thu Aug 29, 2013 11:55 am
Mike many thanks for the prompt and informative reply. I will check with other specialists and investigate the oil/parts on the JEC website. Obvious when you know! Thanks again and I will let you know how I go. :D
