I have fault codes System Too lean both banks I have looked for obvious visual signs for cracks but can't see any. I don't have a smoke test equipment is there any obvious parts to check that would effect both banks
I have no loss in performance either at idle or high revs
I have looked at the MAS sensor all clean filter is clean
all connections from the MAS sensor housing look good
Barrie
PO171 & PO174 System too lean on both banks
Re: PO171 & PO174 System too lean on both banks
Hi Barrie,
No one has come up with a magic bullet to solve your problem possibly because, in a complicated engine management system, there are many possibilities. Unfortunately, in today's world, 'simple is beautiful' no longer applies! If you haven't already done so, I would employ the services of a known expert diagnostic Jaguar specialist like those of our two technical gurus (Dave Marks and Ian at XJK Garages). The problem could still be simple. like low fuel pressure but the car probably requires a deeper level of diagnostics to establish the cause of its fault code readings. Mike.
if too lean on both banks then i would be looking at the induction system
start with the TB, take of the induction pipe and inspect the TB inside, if clean and operating correctly than you can move onto the part load breather pipe,
this is mounted on the left cam cover and goes down the middle of the engine to the TB underneath , these are known to go brittle and split , allowing extra air into the engine , from memory , they are £15 from jaguar ,
other than that , check all induction pipes for splits and holes all round
then its get it plugged into a computer that may be able to help you
