Screen wash cap fallen into the engine!
davidt34
Postby davidt34 » Sat Jun 08, 2013 10:28 pm
I picked up my 1997 xk8 today after having the roof lining re upholstered (the guy did a great job) but I stopped at the garage on the way home to fill up the screen wash tank and when I got home the cap had fallen into the engine bay. It slipped down beneath the washer fluid filler and is now out of sight!.
Is it likely to cause any harm in the engine or will it slip through onto the road at some point?
I can't see it at all now so I can't tell where it's ended up.
Also I've noticed the rear view mirror now has a line where it looks like liquid inside has slipped down from the top. I can only assume the upholsterer removed the mirror and has somehow caused this to happen. It's too late to complain but wondered if this can be fixed somehow.
Thanks!
Dave
oyster
Re: Screen wash cap fallen into the engine!
Postby oyster » Sat Jun 08, 2013 11:41 pm
Hi.
The washer cap is probably no problem. It is is stuck down there somewhere or has fallen out on the road.
BUT!!!!! Your rearview mirror is going to fail shortly. The fluid inside will start leaking. The fluid is agressive and will destroy the area around the gear shifter. Remove the mirror or put some paper around it.
oyster
X-Type 2.2d Estate 06
XK 8 Cab 97
robv12
Postby robv12 » Sun Jun 09, 2013 8:31 am
agreed, the cap has probably gone by now, but a new one and fit, or find one off a breaker
the mirror is beginning to fail, its unlikely the trimmer caused the fault, they have a habit of failing as time marches on, look out for a second-hand one and replace, try NE Jag Spares or EuroJag as your first ports of call
hope this helps
88 3.6 XJ40 EX JDHT
88 3.6 XJ40 SOV
93 XJ40 XJ12
97 Daimler Double Six
97 XJR 300 Manual EX JDHT
55 X TYPE EST 3.0 SP PREM
56 X150 XK
davidt34
Postby davidt34 » Mon Jun 10, 2013 7:08 pm
Hi Guys
Many thanks for the great replies.
I did a 160 mile round trip today so I'm guessing the cap has gone by now!.
Many thanks for the warning about the mirror - I'll order one asap.
Best regards
Dave
