Quick tensioner question
Chris99
Postby Chris99 » Wed Jul 21, 2010 7:56 pm
Hi there,
Just a quick question really.
Are there any visual inspections I can do myself to check my tensioners and their condition?
Or does this require a specialist?
It's an MY 02 XKR, which has now ticked over 18,000 miles, and runs faultless, but I'm guessing it will not have the fully updated metal tensioners.
Chris :D
Nik
Postby Nik » Wed Jul 21, 2010 10:17 pm
Hi Chris ,
You can check the upper tensioners easily by removing the cam covers , examine them really carefully for splits and loose slippers ,
They are likely to be the second generation tensioners that have springs fitted to them , if there is any doubt to their condition get them changed to the latest type :wink: ,
Hope this helps ,
Nik
Chris99
Postby Chris99 » Wed Jul 21, 2010 10:40 pm
That's excellent, thanks
That's another job for the weekend then!
Cheers :D
Chris
analyse
Postby analyse » Wed Jul 21, 2010 11:14 pm
Hi Chris;
Just another small tip I picked up with my car chains -when bought as a non-runner the chains etc. had allegedly been replaced. This proved to be the case however only the top tensioners had been replaced. This only showed up after the car had been allowed to run long enough for the engine to warm up, at which point the warm and relaxed chains started to rattle because the bottom tensioners were not working. Point is this was not noticeable when just running from cold (and engine tight), so well worth a check at full running temperature when everythings nicely warmed up and looose/lubricated. It also shows the false economy of partial replacement..
Best Regards,
Howard.
Chris99
Postby Chris99 » Wed Jul 21, 2010 11:32 pm
Cheers Howard, I'll keep that in mind ready for the weekend.
Chris
Nik
Postby Nik » Wed Jul 21, 2010 11:44 pm
Howards right there but the bottom tensioners are a real mare to check without stripping the front cover off ,
Nik
aaj
Postby aaj » Sat Jul 24, 2010 11:33 am
Chris
It's possible your XK may have the latest tensioners fitted from new.
The last 4.0's had the new system (but not the 4.2 water pump)
Unfortunately, there is no reliable documentation on date of change but if you serch the BB there is further info available. Your Engine No gives the date & time it was made.
If you take one of the cam covers off If you have the latest tensioners from new you will see the Primary Chain is the Morse type (not 'bike' chain) & will see the tensioner has an alloy body.
Make sure you have the correct latest gaskets & sealent b4 you start
Allan Jones
XK8 Registrar
D_Doran
Postby D_Doran » Mon Jul 26, 2010 11:20 pm
I'd agree.. my 2002 XK8 4.0litre has the latest tensioners fitted according to the local main stealer. I'm pretty sure the XKRs were fitted with the newer tensioners before the XK8s, so that would cover yours.
You can just phone the main dealer with the VIN number to be sure.
