It's me, yet again. Thanks for your patience. I think I am suffering from paranoia associated with owning and running a car far better than anything I've touched before
A couple of questions. When I start the engine, I think I can hear a very slight rattle which isn't there when the engine is warm. But if I hadn't read so much about the dreaded timing chain tensioner issue, and only having driven ordinary (and relatively much noisier engined-) cars before, I duoubt I would even have noticed it. It really is the slightest tick, tick, tick. Is it likely to be something problematic, or am I listening too hard?
Second thing. If it is the tensioners on the way out can anyone supply a list of all bits and tools needed to replace the most accessible (and most often faulty) ones and suggest a supplier of parts, please? The engine has done around 100k.
Thank you very much in anticipation
Kevin
