Independent in Romford/Brentwood/Chelmsford area ?
Malc_R
Postby Malc_R » Mon Mar 30, 2009 4:59 pm
Guys
Are there any known good, reliable independent specialists in the above area ? I am looking to get my cam chain tensioners done, and looking for recommendations.
The main dealer 'Grange Motors' in Brentwood will do the job , but they are quoting the £600-mark, and from forum postings it seems the job can be got for around half that at an independent.
TIA
Malcolm
PrideofLyons
Re: Independent in Romford/Brentwood/Chelmsford area ?
Postby PrideofLyons » Mon Mar 30, 2009 5:56 pm
Malcolm
If they'll do the whole lot for that (uppers and lowers) then snatch their hands off - normal main dealer prices are £1000/£1500.
Malc_R
Postby Malc_R » Mon Mar 30, 2009 10:38 pm
Nah - that's just the upper ones ( forgot to mention that :oops: )
dredr62
Postby dredr62 » Thu Apr 23, 2009 3:49 pm
Have a word with LesPauls in Woodford just past the Gants Hill roundabout on the A12. (0208 551 8537). Had upper and lower tensioners, guides, thermostat, water pump, crank shaft pulley, seals and gaskets and both VVT units replaced for just under £1,500. Labour cost was £350 and VVT units were £250 each. This was on my 1998 XJ8. I've used them for last two years to service and look after my XK8 and wife's X type as well.
Service level lot better than Grange and labour rates about two thirds. Plus the job will be done by one of the three highly experienced partners in the business rather than an apprentice trainee.
