Limp mode and poor running
Mini
Postby Mini » Sat Feb 01, 2025 12:58 pm
I have an XK8 1999 with the following IDS codes
Engine control - P0336, P1646
Instrument pack U1260, U1261
Transmission control P1798
Climate control - request cannot be processed due to a bad specification or missing parameters
Restraint control module - communication with module has been lost.
I am guessing the P0336 and the P1798 are the key ones to go at initially ?
Any thoughts ?
Re: Limp mode and poor running
Postby ptjs1 » Sat Feb 01, 2025 7:13 pm
Mini,
First of all, have you tried ensuring that your battery is absolutely fully charged, then clear the codes, then drive the car and see what returns?
It may well be that you have component problems, but I would always start with that approach first.
As you probably know, P0336 & P1646 (assuming they are not spurious) relate to the crank sensor and one of the lambda sensors.
Mini
Postby Mini » Sat Feb 01, 2025 7:17 pm
Battery is new and fully charged.
Astromorg
Postby Astromorg » Sat Feb 01, 2025 11:36 pm
I'd go with that advice to get to a good starting point for what's to come.
Somewhere along the line it looks like your you're going to find an underlying problem with the CAN bus system and maybe the SCM one too as indicated by the P1798. That could be fun!
For the AC problems. start here if possible
http://www.jagrepair.com/images/ACCompr ... 0Codes.pdf
You seem to have quite busy programme with this and the '96 one!
2005 XK8 4.2-S Coupe
2024 XE 300 Sport
