CRANKSHAFT OIL SEAL
lovejags
CRANKSHAFT OIL SEAL
Postby lovejags » Thu Sep 10, 2020 4:14 pm
My seal is leaking on my 2007 Xkr but not bad I take it it will be a big job is it? Also the costing plz.
JimMann
Re: CRANKSHAFT OIL SEAL
Postby JimMann » Thu Sep 10, 2020 6:00 pm
Please note your post has been relocated (moved) to the Engine section of the XK Forum as it is more applicable there.
Jim Mann
Banchory
Postby mike020150 » Fri Sep 11, 2020 9:37 am
You haven't specified whether it's the front or rear crankshaft oil seal which is leaking. Replacement of the front seal is the easier task of the two and has a Jaguar standard repair time of about 4 hours whereas the rear seal would take more than 5 hours. Bear in mind that these times are formulated with warranty work on young cars in mind. Work on older vehicles inevitably takes longer, especially for tasks like these not performed regularly. Mike.
