Engine Warning Light
Zennan101
Postby Zennan101 » Sun Nov 08, 2015 10:54 pm
A wet afternoon in Devon so finally got around to replacing and renewing my speedo cluster and dial cluster lights. I followed all the advice given and disconnected the battery throughout the disconnection and reconnection phase and although a bit of a fiddle the whole job was quite straightforward apart from having to reseat the electrical connectors once.
The lights all work now and it's great that I can now see the speedo in the dark!
Reset the window drops and pleased to see that the seat memory was untouched, just the trip Milagros lost.
The only down side is that now, the Sytems Check leaves the orange engine light illuminated. :evil:
Logic says that this is just an electrical glitch from the disconnection, reconnection, disconnection and reconnection of the battery.
My initial thought is to disconnect the battery for an hour to clear all error codes from the computer memory?
Any other suggestions?
Ex 2010 XF 3.0 Luxury Diesel
Ex 2004 XK8 Coupe
robv12
Re: Engine Warning Light
Postby robv12 » Mon Nov 09, 2015 10:46 am
a battery disconnect is always a code place to start to dump any stored codes, try this, if this fails, a scan is in order
88 3.6 XJ40 EX JDHT
88 3.6 XJ40 SOV
93 XJ40 XJ12
97 Daimler Double Six
97 XJR 300 Manual EX JDHT
55 X TYPE EST 3.0 SP PREM
56 X150 XK
Zennan101
Postby Zennan101 » Tue Nov 10, 2015 5:39 pm
Reset seems to have done the trick. Thanks Robv12 for the confirmation.
Ex 2004 XK8 Coupe
Users browsing this forum: No registered users and 18 guests
