Temperature LCD display light
PTR200Jag
Postby PTR200Jag » Thu Sep 24, 2015 11:25 pm
Just come back from a 90 mile round trip in the dark...something I hadn't noticed before is the lack of a light in the heating temperature lcd display.
Is there supposed to be a backlight in there when the external lights are on ? Or even just a permanent backlight ?
XK8 MY2002
Orkney
Re: Temperature LCD display light
Postby Orkney » Fri Sep 25, 2015 6:17 pm
Hi PTR,
Yes the display is backlit, bit of a faff to change the duff bulbs though. On the 308 it's remove centre console, prize out centre dash plate (that will be different on X100) then remove display unit and turn it over to reveal the bulb holders, brown plastic holders from memory of my last 308. There are a few different coloured holders and therefore bulb wattages around the dash. I got a handful of secondhand ones from Eurojag as no one seemed sure of exact part numbers.
If you decide to go ahead you might investigate those gear change micro witches while your in upto your elbows.
Ian ( in Austria today)
PTR200Jag
Postby PTR200Jag » Fri Sep 25, 2015 6:56 pm
Hi Ian. Thanks for the info,,,, just another job to add to the list again! one of the fog light switches appears to be missing a bulb too!
In Preston....... :lol:
watch out for Cling-ons, keep those doors locked !
XK8 MY2002
