Having just put my 98 XK8 convertible back on the road after winter hibernation. Whilst driving it today I am getting occasionally an error message stating low coolant level. Coolant level is OK. The battery is brand new.
Any possible suggestions to cause will be greatfully received.
Low coolant warning
Loneranger
1998 XK8 Convertible in Sherwood Green Metallic Ivory Leather- Weekend sanity motor 1500 miles pa
2014 Mercedes-Benz C220cdi silver weekday warrior 50k pa
Re: Low coolant warning
Could be as simple as a dodgy connection. The sender unit works by continuity through the coolant - when there's no coolant then there's nothing to conduct the current through and so the warning light comes on. Unplugging the sensor or a bad connection will have the same effect.
Hope that helps
Hope that helps
