Battery Replacement
DougX
Battery Replacement
Postby DougX » Sun Nov 02, 2014 10:10 am
I have a 2005 XK8 convertible and may need to replace the battery as on occasions seem to be getting dash warnings for things that are not at fault, i.e. low fuel (had a full tank), low water coolant (well full), etc. It has been suggested that the battery could be the cause of this. I have now connected the car battery to my CTEK charger in the hope that I can retrieve the issues with the battery. However, if this fails I want to get a battery that will last as long as the exisiting one i.e. 9 years or more!!! and don't want to buy something that will last 5 minutes. Any suggestions? Also, I have read on other forums that it may not be a case of taking the original one off and putting another on. Obviously I will have to reset the radio, but is there anything else that may need attention?
Something else I have noticed on the other forums is a suggestion of a venting kit?? Again, has anyone any knowledge what this relates to? Any help would greatly be appreciated. :?: :?:
Re: Battery Replacement
Postby mike020150 » Sun Nov 02, 2014 10:25 am
Hi Doug,
Your existing battery should already have a vent tube fitted as standard. It vents any gases below the boot floor. Due to its enclosed location in the boot, make sure any battery you buy has a suitable hole to attach the vent tube. Both the radio and the window drop will have to be reset after fitting the new battery. Mike.
Postby Brakebuster » Sun Nov 02, 2014 11:14 am
if you want to match the original battery , then there is only one place to go to be honest
Jaguar
they sell original spec batteries, that will fit , and at around £120 isn't that expensive considering what your driving,
DougX
Postby DougX » Sun Nov 02, 2014 11:46 am
Thanks for the comments. I will contact my Jaguar dealer for a price. I already get 10% discount and may be able to obtain more, so if I can get one for £100 I wil be more than happy.
