ABS light
para
ABS light
Postby para » Mon Aug 26, 2013 1:17 pm
Hi everyone
One simple question the abs light coming on intermittently is a
common problem with these cars ive read where one member
said he just ignores it but if the abs light comes on when the
car is in for an mot is it a failure i am guessing it is
regards para
2002 Xkr 4.2 Adriatic blue reg Dez 7571
aaj
Re: ABS light
Postby aaj » Mon Aug 26, 2013 1:39 pm
Para
The most common reason for the ABS light to intermittently show is a broken wire in the drop cable to the ABS Sensor
A code reader will identify if Left or Right is at fault
You can either replace the cable or make a repair if you can tell where the break is
Good Luck
Allan J
XK8 Registrar
para
Re: ABS light
Postby para » Tue Aug 27, 2013 3:23 pm
thanks for the reply ALLANJ great info will look into it
regards para
