I am trying to replace the bulbs in the header console of my 2002 convertible. Do the plastic lenses need prising out or does the header console have to be completely removed?
thanks,
Derek
Header console bulb replacement
Re: Header console bulb replacement
Hi Derek ,
The complete unit comes out , it's held in by three spring retaining clips , just pull down gently equally on all sides and all will become apparent ,
Hope this helps,
Nik
Hope this helps,
Nik
Thanks for that Nik. I always worry that I 'll end up doing more harm than good with little jobs like that. I had to prise the front off with a flat srew driver then the console came straight down as you said. The bulbs hadn't blown - I bought some blue LED's, which I swapped out for the originals. I quite like them so will be doing the footwells next; do you know if that's straight forward?
Hi Derek ,
The footwell lamps should be easier than the console lamps
have you used BLUE Leds for the console lamps or WHITE
In theory the Leds should last up to 20,000 hrs,
Best of luck ,
Nik
Best of luck ,
Nik
