windows up or not....
dogbitedavie
Postby dogbitedavie » Wed Jul 14, 2010 10:16 pm
I have a problem, whereby, if you raise the drivers door window with the one touch automatic button, the window raises, but then goes back down again to about half way.
if i keep my finger on the button, the window does shut ok.
the window drops/raises as it should when the dooor is opened (convertible xkr)
I have tried the reset, but still does it.
its not such a problem, but when its raining, and you want the window up in one touch, its annoying when your still getting wet ! :)
Postby mike020150 » Thu Jul 15, 2010 11:24 am
The onetouch operation is designed to drop 200mm if an obstruction is detected so the most likely cause is stickiness in the window guides. Hence, it may be worth trying a suitable lubricant in the guides, like one of the silicone lubricants sold by Halfords etc just for this type of purpose. Mike.
dogbitedavie
Postby dogbitedavie » Tue Jul 27, 2010 9:39 pm
Thanks for that Mike, the window seems to have cured itself, but will give it a squirt of lubricants anyway !
