The Drivers seat keeps blowing the 10amp fuse when I adjust the seat forward. This happens before it reaches its full travel.
Once I replace the fuse the seat will travel back ok but will blow the fuse going forward.
I have checked for obstsructions and any bare wires but can't see any.
I also cannot move the seat far enough forward to be able to get to the rear mounting bolts so I can't take the seat out to assit in finding the fault.
Any help will do.
It's a pity that my wife is a foot shorter than me but it does stop her driving it.
Driver Seat Electrics
In the absence of access to JDS or the Autologic system, it would be worth using a meter to check the wiring around the connector whilst moving the seat. It's an obvious place where a stray wire could short out when the wiring moves with the seat. If nothing is found, next suspect an issue with the limit switch/motor or seat mechanism itself. It sounds like a good supply of fuses will be necessary to complete the diagnosis and/or move the seat forward to gain access to the fixings! Mike.
I had this problem and found that the seat would move fully forward and backwards when there was nobody sitting in it. I removed the seat, lightly greased the drive screw from the motor and the runners, replaced the seat, ran it back and forth with no load added a few times and it now works fine.
Hope this helps - good luck
Kevin
Kevin
Re: Driver Seat Electrics
I had a similar problem with the seat back tilt blowing fuses. It was down to chafing of the wires near the hinge and shorting out on the seat frame. Fortunately I was able to remove the seat from the car.
Y2k XKR convertible
