head rest not working
Posted: Mon Aug 25, 2008 10:29 pm
Hi any advice on the this one the drivers side head rest is stuck in the down position the passenger one works fine when you move the seat back forward it lowers and rises when put back.
Drivers side head rest is stuck, cannot pull it up manually, did not want to pull to hard mind.
2001 model XKR
Anyone know if this is a common problem, don't want to go taking the seat apart until I know if it is fixable any suggestions on what checks I could make and how to access the wiring for the seat to check it. Have a volt meter to check circuits.
thanks in advance for any tips.
2001 model XKR
