apologies
pmurf
apologies
Postby pmurf » Mon May 12, 2008 4:20 pm
it would help if i would read first and ask later. sorry for asking the well worn question. im off to try all the suggestions to see if it gets me anywhere. boot lights, vanity lights, glove compt all negative, so that whole hidden tracker thing looks like a possible.
cheers all
P
Postby mike020150 » Fri May 16, 2008 6:03 pm
The current draw from a tracker is low. In some instances they have been known to cause flat batteries after 2/3 weeks. Of course, if the tracker has a fault, that's another story. Mike.
BestGear
Postby BestGear » Wed Jun 11, 2008 10:24 pm
Did you find the tracker unit?
Mine was mounted above the CD changer "rack" where on a convertible the hood pump is located.
There is a fuse in the lead from it to the battery, so you could disconnect that and see...
David
