Bulb Holders
Posted: Tue Sep 11, 2007 9:44 am
by John1963
Can anyone tell me where to get bulb holders from. I am replacing my orange side reflectors for running lights, red at the rear and clear at the front.
Posted: Tue Sep 11, 2007 10:23 am
by designxkr50
It depends where you are buying the running lights from. You might find that they come with them already. The red running lights we supply come complete with the bulbs and holders.
Posted: Tue Sep 11, 2007 12:03 pm
by Bassman
Otherwise they are just the same as Mondeo/Escort ones
available at car accessory shops
Posted: Tue Sep 11, 2007 3:21 pm
by John1963
Thanks, sounds like they are not going to be expensive then.
Posted: Wed Sep 12, 2007 7:03 pm
by MarkyM
From memory (I fitted my side cruise lights almost 2 years ago) the actual bulb holders for the 501 bulbs were actually built into the connector behind the wing. All that the clear reflectors had were the ability to lock the bulb holder to the reflector.
To recommendations
1) Use chromed amber 501 bulbs
2) Use a smear of silicon to minimise water ingress
2yrs later mine are all still working fine
Mark
Posted: Wed Sep 12, 2007 9:07 pm
by WULLIE4567
Hi John
I have just bought 4 off rubber push in bulb holders from a motor bike agent. Removed the four orange running lamps drilled holes to suit, pushed the rubber bulb holders into place,with 5 watt bulbs, cut the plug connectors off the jags wiring harness and used connector blocks to rejoin wires, now all lamps light up orange looks cool not to bright from front or rear but bright from side. Note connector blocks were taped up and sprayed with waxoil.
