XKR ELECTRICAL IGNITION FAULT
Graham007
Postby Graham007 » Mon Aug 27, 2007 10:37 pm
This is from the engine forum now moving to electrics.
I have an XKR made in 1997 with a new engine fitted in 2003 it will not start . The car had been in my garage for two weeks it started then died away . It now will not start it turns over ok there is fuel but no electrics to the ignition the coils have no power to them , there is power to the fuse which is ok and there are no error messages . The cut out switch is ok as are all the fuses and relays. The fuel pump is ok .
Many thanks Graham
scallan1956
Postby scallan1956 » Sun Nov 02, 2008 4:54 pm
Hi, I had a similar proplem with my 98 XK8, It started then just died not a
sudden cut out, after visiting this forum. I was able to find a double fault.
First fault was electical connection on the back of the throttle body, I took it apart cleaned connections and re asembled it, still not starting? :(
Next thing to check was the relays which give power to engine management system, theese are hidden away in the engine bay n/side
under the black plastic cover, the two small black sleeve covers will reveal the relays, as soon as I lifted theese sleeves it was easy to see the proplem two of the relays were loose one almost dancing around, after lifting out and cleaning the pins I replaced
them back in the same places as removal. Put ignition key in and turned
to start engine, hey presto the sound of 8 cyl engine purring away. :D
To end this story the car has never failed since. Hope this maybe of help
to anybody who suffers the same proplem.
