Headlight washers
Posted: Fri Aug 29, 2025 6:02 pm
I have a 2003 XK8 with headlight washers that are working but the offside one doesn't retract back into place as the washer unit clip has become detached from its fixing point under the headlight.
Does anyone know if it can be re-fixed without the headlight being removed?
Maybe through the wheel arch liner access panel or is it possible to do it with maybe a pair of chopsticks through the aperture where it should retract to .............keyhole surgery style?
