Dimmer Control Module 2003 XKR
Posted: Mon Sep 25, 2023 1:40 pm
by royking999375
Current issue regarding the dashboard illumination, all working fine until headlights are activated resulting in the dashboard lights going out. I have had the main dashboard inspected and all appears to be in order. The next step is to check the dimmer switch and the dimmer control module. The switch appears to be functioning OK so I need to check/replace the dimmer control module.
The question is where is it located? Has anyone experienced this issue and if so did you manage to locate this particular module? All assistance greatly appreciated.
Re: Dimmer Control Module 2003 XKR
Posted: Tue Sep 26, 2023 2:21 pm
by Astromorg
In answer to the main question, the dimmer module is located next to all the fuses in the Fuse Box on the end of the dash, on the driver's side. It's upside down wrt the part number etc that is LJA6490AC. SNG Barratts offer new ones on special order for £115, and used ones on ebay look to be all from abroad at the moment. The good news is that AutoReserve, a good, reliable used parts provider is offering one for less than £5 today!
I spent a bit of time looking through the relevant electrical diagrams for dimmable lighting and headlights and can't really establish how this sort of problem can arise, though accepting that funny things can happen inside modules! So just a thought, are you sure your dimmer control is turned up to more than minimum brightness (ie from no dash lighting) because that allows the instrument lighting to come on with ignition, but go out when the lights are turned on? Specifically, it's the side lights that do this, not the headlights so it may not be your solution as you say it occurs when the headlights are activated?
Posted: Wed Sep 27, 2023 9:23 pm
by royking999375
Thank you so much for your comprehensive response and the time taken to look at the issue.
I tried a replacement dimmer module without success. As suggested I looked at various settings for the dimmer switch and they all returned the same result. Upon further investigation it appears that the side and tail lights only come on when the main lights are activated. Could the dimmer switch be faulty?
As ever I will appreciate all and any input.
Roy
Posted: Thu Sep 28, 2023 8:43 am
by Astromorg
Roy, your discovery that the side lights do not come on until the headlights are switched on is the key to unlocking this whole problem :D
You need to remove the lower half of the cowl surrounding the steering column (some recessed Posidrive screws) to give you access to the wiring to the steering column indicator/lighting stalk switch assembly. I'm sure that you will find that the Red/White wire that should go to that switch has detached - probably at its soldered connection.
That wire is switched to Ground to switch on the side lights and, importantly, through a spliced-in additional wire, also the dimmer switch module. With it disconnected, the dimmer switch will never operate correctly, but the side lights will work through the headlight circuitry in the switch when the headlights are switched on. This diagram should make it all clear
Posted: Thu Sep 28, 2023 1:41 pm
by royking999375
Once again thank you very much for your insight. I have followed your suggestion and have identified a loose green wire, but cannot relate this to the red white cable mentioned. I attach a photo and ask if you can help some more.
Roy
Posted: Thu Sep 28, 2023 9:27 pm
by Astromorg
That green wire is one of the switch manufacturer's wires from inside the switch to the outer terminal board to which the switch connecting harness is soldered. The Jaguar harness then has a plug and socket connection to the switch harness. The switch manufacturer's wire colours are not recorded in the Jaguar electrical diagrams, however, here are a couple of photos of mine so you can see where it should be re=attached.
My XK8 is the same MY as yours so everything should match up! Green wire shares a terminal with a larger gauge Red/Yellow wire.
Whether you'll be able to solder it back with the switch in situ will rather depend upon your general dexterity I guess. It's certainly a tight situation! Don't forget to disconnect the battery - there's bare live terminals about just waiting to be shorted!
Just out of interest, what's that grey ribbon cable in your photo? It doesn't look original!
Posted: Wed Oct 04, 2023 6:55 pm
by royking999375
I can report back that after reconnecting the green wire the lights all function correctly. I am unable to provide further insight regarding the terminations for the ribbon cable as it was unnecessary to remove the top half of the steering column shroud, as this was where the cable disappeared behind.
There has obviously been previous work in this area as it was necessary to extend the green wire to prevent it being pulled off again upon activation of the lighting stalk.
Can I once again thank you for your various postings, which have led me to the solution? Your input and assistance has been very much appreciated.
Roy
