How to charge 2007 jaguar xk Battery - Please help
leelane588
Postby leelane588 » Wed Jul 05, 2023 7:08 pm
Hope someone can help - I have a ctek mxs 5.0 battery charger - what is the best way to charge my 2007 xk battery please ?
Can you do it through the boot passenger side vent or do I need to connect to battery
Thank you
colin.white1958436
Re: How to charge 2007 jaguar xk Battery - Please help
Postby colin.white1958436 » Thu Aug 03, 2023 4:47 pm
i have a 07 xk convertable with similar battery charger yes open the boot rmove the small black vented panel on the left hand side ie near side look down inside the main battery positive cable has a rubber shroud over it slide it up to get access to the connection .
Place the positive on that and the negative on one of the fixing bolts in that area and away you go !
