Temperature Gauge Problem
Posted: Mon Feb 01, 2021 11:51 am
Under normal circumstances when my engine is at the proper operating temperature the temperature gauge needle is exactly on the ‘normal’ position on the gauge. Recently, however a fault with the gauge has developed: When I was sitting in the car and before I put the key into the ignition I noticed that the gauge needle had not returned to the zero position on the gauge, as usual, but had, when last switched off , only returned to a position about 1/8th of an inch up the scale from the usual zero position. I started the engine and watched as the temperature increased, with the needle passing the ‘normal’ position on the scale and stopping at a point about 1/8th of an inch above it. The needle had, in fact, travelled exactly the same distance that it normally does but between two different places on the gauge. The engine was not overheating.
When I turned off the engine the needle again failed to return to zero, but, this time, stayed even further up the scale, in fact, just below the ‘normal’ position. The next time I started the engine the needle climbed to almost the top of the scale when the engine reached it’s proper operating temperature and again, the needle travelled the same distance on the scale but between different places. Apart from minor discrepancies in the needle position, when the engine is running and when the ignition is off this is the way things are, now, with the temperature gauge on this car. I cannot help feeling that as this is not a temperature problem, only a temperature gauge problem, there would be little point in investigating the heating/cooling side of things. Replacing the temperature gauge is not an option.
Can anyone make any suitable suggestions?
