Alternator Removal - 1996 XK8
nrandlexj40
Postby nrandlexj40 » Sun Sep 27, 2020 5:55 pm
I'm trying to remove the alternator on my 1996 XK8 and it's proving a bit of a puzzle.
Removal of the air filter box gives access from above to undo the bolts - but there is not enough room to remove the alternator.
From below - I've removed the oil filter and alternator mounting bracket - but there isn't sufficient room to get it out that way either.
Is there a technique to remove the alternator? (other than paying your dealer 8) )
Thanks in advance
Neil
1996 XK8 Coupe
2000 S-Type 3.0 V6 SE
2010 XF 3.0 V6
Previous: 1993 XJ40 Sovereign | 2004 X-Type 2.5 V6
Astromorg
Re: Alternator Removal - 1996 XK8
Postby Astromorg » Sun Sep 27, 2020 7:21 pm
The additional step in Jaguar's method is to remove the fan and motor assembly from radiator. This should allow the alternator to be moved forwards, then turned through 90 degs and pulled out upwards between the engine and radiator.
When refitting, its also recommended that the spacer bush in the mounting bracket is eased slightly rearwards. I'd presume that this increases clearance until the through bolt is tightened and puts the bush back.
2005 XK8 4.2-S Coupe
2024 XE 300 Sport
Andy P
Postby Andy P » Sun Sep 27, 2020 10:31 pm
Hi nrandlexj40,
There is a good write up of the procedure with photo's here:
https://www.jaguarforums.com/forum/xk8- ... nt-126933/
As they say a "photo is worth a thousand words" :)
Hope that helps a bit anyway.
Take care.
Andy. :D
nrandlexj40
Postby nrandlexj40 » Mon Sep 28, 2020 8:58 am
Thanks guys
I'll give this a go - there certainly isn't much room in this engine bay - makes me miss my old XJ40 :-)
Neil
1996 XK8 Coupe
2010 XF 3.0 V6
nrandlexj40
Postby nrandlexj40 » Wed Sep 30, 2020 8:21 am
Thanks again guys
Removing the fan pack gives plenty of room to swap the alternator - and whilst I'm there I'll swap the serpentine belt :-)
Hopefully I'll get the car in for an MOT soon after many years off the road
Neil
1996 XK8 Coupe
2010 XF 3.0 V6
Andy P
Postby Andy P » Wed Sep 30, 2020 11:14 am
Glad your getting there.
Let us know how you get on with the MOT if you can.
Good luck and take care.
Andy :D
