2003 XKR Alpine Navi - SOLVED
Posted: Thu Jun 27, 2019 9:13 am
by bouncer99
I have the elderly Alpine Navi unit in my 2003 XKR.
Recently I was forced to change the battery since when I am only seeing the clock and seem to be unable to start the Navi.
The must be a button press sequence to bring up the menu where I should enter the code.
Anybody help with this one?
My thanks in advance.
Alexander
By the way, has anyone got an old DVD of Europe (Germany) and are willing to sell?
Re: 2003 XKR Alpine Navi
Posted: Thu Jun 27, 2019 11:14 am
by Lucky
I have a 2001 (2002MY) X100 so I assume I have the same sat Nav system as you. However, I've had the battery out of mine a few times and never had a problem with the Sat Nav - it has certainly never asked for a code (which I don't have anyway). Have you tried ejecting and reinserting the CD? I assume other things, such as the radio, are working as normal since the battery swap? I don't have my handbook to hand, but is there a separate fuse for the Sat Nav?
Sorry - not much help I'm afraid.
Posted: Fri Jun 28, 2019 5:08 pm
by Astromorg
Fear not, there are no codes associated with the satnav.
If the analogue clock is showing, you should push the joystick In to Enter. That should bring up the Caution page. Push Enter again to get to the map and that should be that.
Let us know if that doesn't work in case a deeper solution is required!
Posted: Sun Jun 30, 2019 7:10 am
by bouncer99
Bingo. Problem solved. I had not used the radio since fitting the new battery. When I switched the radio on as 'Lucky suggested it immediately asked for the code. I had fortunately noticed 4 numbers scribbled on the back of a receipt which came with the car. On entering the radio code the Navi immediately and I was much relieved. The fact is that one cannot get into the settings for the clock and it was 2 hours out showing GMT Winter Time. I live in Germany and need CET and Summer Time.
Many thanks though for the feedback especially 'Lucky'
Even help which fails to lead to an instant cure can be vital in directing the mind to see the problem in a different light.
Still looking for a Euro DVD though.
