Light indicator on gearlever
alsjaguar
Postby alsjaguar » Fri May 25, 2018 2:10 pm
On a 1996 XK8 I have all the lights illuminated in turn on the indicator top plate when moving the gear lever from Park to Drive which is quite normal but in the Drive position the light does NOT illuminate what is the cause and how is that fixed please.
JimboV8
Re: Light indicator on gearlever
Postby JimboV8 » Fri May 25, 2018 2:47 pm
Suspect a slight misalignment that will require removal of the plate to gain access. :D
2012 XKR, Black pack, Aero pack, Speed pack 8) :mrgreen:
​Past:-87'XJS 3.6L, 93'XJ40 3.2L gold, 95'XJ6 4.0L sport, 00'XJ8 3.2L sport, 2005 XK8 4.2L, 2009 X150 5L Portfolio coupe, in that order and enjoyed all of 'em. :D
Astromorg
Postby Astromorg » Fri May 25, 2018 5:03 pm
The general illumination of the J Gate is from two small bulbs with blue plastic caps. The selector positions are lit by LEDs, one per position. Both bulbs and LEDs are soldered to the circuit board within the J Gate.
The link will take you to an informative series of helpful posts and some good photos
https://www.jaguarforums.com/forum/xk8- ... light=gate
2005 XK8 4.2-S Coupe
2024 XE 300 Sport
alsjaguar
Postby alsjaguar » Sun May 27, 2018 2:29 pm
Thanks for that information I think I will live with the light out.
