Only one low beam working.
FrankC
Postby FrankC » Thu Jul 20, 2017 4:34 pm
I noticed yesterday that my low beam drivers side was not working. Its an H1S HID unit in there. With the balast fixed to the rear. So I bit the bullet, they are very expensive, and ordered a couple of new ones.
They arrived today so I stuck it in there................. Still not working. Tried the other new one............... nothing.
I think the fuses for the low beam are in the engine bay box, 10 amp? Checked all the 10 amps, could not see any numbers as I think its fuse 6 or 9. So I simply checked all the 10 amps. All seem fine.
I do not have a meter.
Suggestions?
Re: Only one low beam working.
Postby mike020150 » Thu Jul 20, 2017 4:42 pm
Without any diagnostics, life these days is difficult. have you tried swapping the burners (bulbs) between headlamps to see if that is the root cause of the problem? Mike.
FrankC
Postby FrankC » Thu Jul 20, 2017 5:09 pm
I tried two brand new bulbs in there. All the same I am going to put a new one in the side I know is working, just in case. I think its a wiring or fuse problem. Fuse 6 or 9 in the engine bay fuse box? Problem is the fuse positions do not seem to be marked.
Thanks for the reply.
FrankC
Postby FrankC » Thu Jul 20, 2017 5:57 pm
Just been out again. Took out the working bulb. Then got the new bulb that would not work on the drivers side. Put it in. Works. So it must be either a fuse or wiring. :?
andypryce
Postby andypryce » Thu Jul 20, 2017 7:26 pm
Check any earthing points nearby, had exact same issue on my X350 and was the earthing point behind the lamp.
XF Sportbrake 2020 / XK8 1998
FrankC
Postby FrankC » Thu Jul 20, 2017 8:04 pm
Thanks will do. Just had a thought. Perhaps I will try a wire just touching the rear of the ballast and the other end connect to earth..........
Other things I have done. Checked fuse 6 20amp. Its fine. Swapped over relays put another working one into 5 slot, still not working. Will give that earth idea a go though.
andypryce
Postby andypryce » Thu Jul 20, 2017 8:14 pm
Be careful though, they operate at high voltage I believe.
FrankC
Postby FrankC » Thu Jul 20, 2017 8:31 pm
Nope Even earthing the rear has not helped. :?
andypryce
Postby andypryce » Thu Jul 20, 2017 8:59 pm
can you check for voltage supply with a voltmeter? Does sound like no power to it then, in which case I guess a question of working back from the light until you get voltage, pain in the butt though...
FrankC
Postby FrankC » Thu Jul 20, 2017 10:05 pm
Looks like a garage job. The wheel needs removing and the liner to gain a bit more access to the wiring. I have emailed the company that supplies the OEM leads from the H1 bulb to the supply. May have to buy one of those and work out how to fit it. Such a confined space.
Thanks for the suggestions Andy, keep em coming :wink:
andypryce
Postby andypryce » Thu Jul 20, 2017 10:40 pm
Agree sounds like a garage job, unfortunately. Yes the access is awful. Let us know how you get on.
FrankC
Postby FrankC » Fri Jul 21, 2017 12:00 am
Thanks Andy, yes I will.
Had a reply from the wire company. Interesting 'English'
"Hello Frankc
Yes we have you need part
can you tell me how many do you need this ?
Sword"
Also emailed my garage. I have faith that they will sort it.
andypryce
Postby andypryce » Fri Jul 21, 2017 8:39 am
pretty much guarantee that if you order that part from then, it won't be the one you want!
FrankC
Postby FrankC » Sat Jul 22, 2017 6:27 pm
Progress.
First off that email I copied on to here. I think its a con. I had a very similar email when I was looking for a bonnet liner. Same sort of wording and exactly the same price quoted. £65. They also seemed very interested in my paypal and credit card details. Steering clear I think unless anyone on here has used them?
Anyway back to the Progress bit.
After much checking. Pulling connectors off etc I finally tracked the feed wire for the dipped headlights going into a large connector on the back of the headlight system. When I switch on the dipped beam this wire goes live! So I know the feed is getting to the headlight system. So somewhere between this connector and the dipped beam is a bad bit.
I also noticed though that the auto leveling does not work on this side. So I now have to work out which wire runs both the headlight and the auto leveling. As the main beam works I am assuming that the same earth is used by dipped and main beam so I can rule a bad earth out? Unless the wiring runs from the dipped beam to the leveling I may be able to discount a loose wire in the rear of the dipped beam connection.
Any links to the auto leveling wiring system? Got the main wiring for the HID system but no detail in the actual leveling bit.
So suggestions as to what to check next?
andypryce
Postby andypryce » Sat Jul 22, 2017 11:54 pm
Have you checked the actual plug that goes into the HID unit itself? If that is live then it has to be an earth issue. As to the self levelling bit, no idea, sorry!
