Rear view mirror & auto lights X100
Terry1961
Postby Terry1961 » Sat Feb 25, 2017 12:24 pm
A few weeks ago I rebuilt my dimming rear view mirror, using a new glass from MirrorJohn. Works a treat, BUT afterwards the auto lights function has failed. With switch in auto position the lights are always on, no matter how bright a day it is.
I've been searching online and found info on how it works, sensor in rear of mirror (faces forward), signal from it goes to the lighting stalk switch and then to a control unit presumably behind the dash. Info has it that the input to the control unit is high, 12V or similar and the sensing circuit in the mirror simply pulls the signal down to ground.
So it seems to me the easy way to prove if it's the mirror is simply to unplug it. Sure enough with the cable disconnected the lights go out. If it hadn't it would point to either a wiring type fault or a dodgy control unit.
If I'm missing something please holler!
Now, I know the light sensor on the rear of the mirror is working, it's also used to control the mirror dimming function, and that works perfectly, so my reasoning is that something is toast on the pcb inside the mirror.
So my question is,
A) does anyone happen to have a circuit diagram of said pcb to enable fault finding?
B) if not does anyone have a scrap mirror lying around that I could scrounge the pcb from? It shouldn't be too difficult to trace the circuit out and then suss out how it works (my background is 40 years in the electronics industry). I don't want to dismantle my mirror again until I have an understanding of how it all works, I could be Jagless for a few weeks :)
Once I have a circuit drawn out I will put it on here for all to use etc.
Terry
Re: Rear view mirror & auto lights X100
Postby mike020150 » Sun Feb 26, 2017 11:16 am
Hi Terry,
Good luck with this project. Most queries I receive about the interior mirror concern it leaking its nasty liquid onto the centre console where the only option is replacement. Perhaps someone with this latter fault could send you their old one for you to experiment with it? Mike.
Terry1961
Postby Terry1961 » Tue Mar 07, 2017 9:38 pm
Hi Mike
Sorry, only just seen your reply.
Yes I've heard of the leaking fluid, there's lots of grim tales around about it :) It prompted me to act quickly when the mirror failed.
So far no one has offerred a board sadly. It would be worth doing if I can get hold of one. Fingers crossed.
Terry
